Home > Maintenance & Mods (L322) > Suspension height help needed, bit urgent, panicking! |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6369 |
Maximum height at access is 1.83m. If you drop it down and lock it in access mode it should be ok, the difference in height of the tyres won't be that much, you could always deflate the tyres and reinflate at the BP on the other side? Discovery 4 HSE
21st Jul 2016 8:33am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35312 |
just drive into the 'over 1.83' lane and you will probably find that eurotunnel wont make a fuss and will let you stay there..
21st Jul 2016 9:01am |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 |
Thanks so far.
21st Jul 2016 9:05am |
When I went in the lower carriage in March I had mine in Access height on std tyres but there was still a good few inches room above the roof aerial which is the highest point.
21st Jul 2016 10:12am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Can you not use the IID Tool to deflate all the airbags and take the suspension right down to the bump stops. Then it should hopefully be under the 1.85m limit. Once on the other side you can use the IID to reinflate the bags to normal. |
21st Jul 2016 11:21am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Rather than deflating the bags it would be quicker and easier on the pump just to lower the suspension all round by the maximum which is 30 whatevers ( the tool never specifies if it is mm) and at the other side simply go to restore settings and restore your original settings . 2008 MY Supercharged
21st Jul 2016 12:10pm |
As said above the height will be OK but as STAN says if you go into the over 1.85 lane AFTER checking you will be put in the Large Vehicle carriage (But don't spread the word) |
21st Jul 2016 1:07pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16286 |
Remember that old friend... SODS LAW!!! If you mess with the suspension settings on iid you'll bring up a fault etc...
21st Jul 2016 2:49pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8517 |
had an argument with a young chap at the folkestone end one time when I was trying to go through the High lane. He was insistent that it would fit in the lower carriage and that I should cross over to the low lane just before the High Kiosk (was in the high lane). He was very insistent......it will fit you NEED to go in this lane now.... you mare making a queue......go this way now.....wouldnt listen to me up until the point i told him, by shouting and swearing that I had booked an high lane ticket that he was a cheeky little and that he should shove the train up his own tunnel...... There is nothing that can't be fixed with a hammer😜😜
21st Jul 2016 9:58pm |
So, as you all told me, unnecessary panic.
22nd Jul 2016 12:39pm |
See! Trust us and relax! Discovery 4 HSE
22nd Jul 2016 1:10pm |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
A word of caution re booking <1>1.85.
22nd Jul 2016 2:26pm |
same price whether over or under , its carriage availability thats a problem.... ... - .- -.
22nd Jul 2016 2:42pm |
I do trust you guys which is why i came here first!
22nd Jul 2016 10:26pm |
