Home > Maintenance & Mods (L322) > Typical
steadyaway
Typical
So. Warmest day (ish) of the year and my air con has decided to give up. It actually blows warmer when I hit the max button than when it's switched off. It was working fine in the warm spell at spring bank so I suspect that all the gas has fooked off. Halfrauds sell a two part kit by STP for £60 plus £10 surcharge for cylinder disposal. Has anyone used one of these or anything similar please and if so do they do what it says on the tin?
Post #396637 18th Jul 2016 6:34pm
For that sort of money you should be able to get one of the main fast fit centres to degas and regas it for you Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #396641 18th Jul 2016 6:44pm
steadyaway
Cheers nmj. I have considered this, but if it is only partially degassed, then this kit should do up to 3 refills. However if it is completely empty it will not fill the system. One part is a pressure gauge which costs £20 which will indicate how full/empty the system is. Also I could use it on the other car if required.
Post #396642 18th Jul 2016 6:49pm
kbald
I wouldn't bother with those diy kits there are loads of threads on them online saying how dangerous they are and can cause more damage than they are worth. Something to do with only monitoring one side either hot or cold whichever you fill! Have a look on group on always loads of places doing Regas offers!
Post #396650 18th Jul 2016 7:13pm
mzplcg
Kwik Fit used to do it for £49
https://www.kwik-fit.com/air-conditioning
Post #396655 18th Jul 2016 7:20pm
steadyaway
Cheers for the link. I might go for that. Thumbs Up
Post #396661 18th Jul 2016 7:30pm
gerrym
There is a Groupon deal at ATS Euromaster at the moment.
http://www.atseuromaster.co.uk/special-off...conditions
£32.95
Cheers
Gerry
Post #396667 18th Jul 2016 8:18pm
steadyaway
Oh this is getting better and better. Cheers Gerry. Thumbs Up
Post #396669 18th Jul 2016 8:23pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
on a side note if the gas has gone then i would be trying to find out how it left and a company will be able to tell you that where as a tin from halfrauds not so much L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #396692 19th Jul 2016 4:56am
^what he said.
if the gas has simply left through age, it is definitely worth getting it pressure tested otherwise you could end up throwing money into it and it simply vents away (which is bad in its self)
a garage will put a vacuum on the system, to see if it has a leak, then if it does they will re-pressureise it with nitrogen and a fluorescent dye which shows up under UV. this can then be used to locate the leak. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #396759 19th Jul 2016 4:49pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Groupon often have local garages as low as,£19.99. Worth a look. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #396764 19th Jul 2016 5:37pm
holidaychicken
Kwik fit had two goes at doing mine and although they said the system didn't show a leak it was leaking and they refunded me. I then replaced the condenser and got kwikfit to fill it again and it's been fine for a couple of years now
Post #396771 19th Jul 2016 6:51pm
steadyaway
Done the Groupon thing and got it booked in for Saturday morning at a local place for the princely sum of £24.50. Just hope it's gas and not a leak.
Post #396985 21st Jul 2016 1:24pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
If it is low on gas pressure then you do have leak somewhere, fridge systems don't 'use' any gas they just recirculate it. The other thing is that topping up a system that has a leak will give an imbalance in the blend of gas used because the part of the blend with the smallest molecules will leak away first. Make sure wherever you have it done that they vac out the system and cure any leak before refill with new gas. There are a lot of Cowboys out there. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #396986 21st Jul 2016 1:33pm
steadyaway
Post #397008 21st Jul 2016 3:13pm
