Home > Technical (L322) > Radweld? |
Jones S13 Member Since: 16 Jul 2016 Location: birmingham Posts: 8 |
Don't do it, horrible stuff to clean out. Can cause other issues as well. |
17th Jul 2016 8:20pm |
Show n shine Member Since: 01 Jun 2016 Location: Hertfordshire Posts: 55 |
A big nooooooo |
17th Jul 2016 8:30pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Nope!
17th Jul 2016 8:35pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
It has a very mixed reputation - particularly with modern / complex cooling systems.
17th Jul 2016 8:36pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 |
Thanks all. Alistair's reply above is kinda what I thought and what prompted me to ask rather than JFDI. Probably fine for a 1969 Cortina* but not these days!
17th Jul 2016 8:38pm |
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 |
JFDI
28th Jul 2016 8:31am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
Mine does the same but I can't actually find the leak. I keep some coolant to the right dilution in a bottle in the boot and top up every now and then. I tend not to wait for "the bong" but just check it cold every so often and add a cupful to bring it up to the mark. Car runs sweet enough, if and when it gets worse I'll get it looked at. Geoff |
28th Jul 2016 8:57am |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 |
this may help find your leak then it's a case of fixing it i would use metal putty as a temp solution https://www.amazon.co.uk/Torch-Detection-C...B00TU8VCB4 L322 2008 vogue
28th Jul 2016 9:31am |
Ivor, when I decide to investigate further that looks like a great way to go - thanks Geoff |
28th Jul 2016 10:04am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
Use K-Seal - doesn't clog up coolant passages etc. |
28th Jul 2016 4:08pm |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 |
Just been looking at some of the reviews for k-seal, seems some people did have problems with it clogging up the system... QUID FACIUM TIBI
28th Jul 2016 7:33pm |
It's just fine particles in suspension in a solution which becomes some sort of polymer when it comes into contact with oxygen, it can't clog like Radweld-style stuff does. |
28th Jul 2016 7:59pm |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
+1 for this. I used it on 2 P38's, both of which developed heater "O" ring problems around 70k miles. They both went to over 100k, before I sold them, with no further coolant problems. 2017 5.0 Autobiography Supercharged 2005 Merc SL350 2005 Disco HSE 2.7 oil burner |
29th Jul 2016 6:42am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Radweld has changed over the years, it's now similar to K-seal, both are fine and designed not to clog the heater matrix, which is usually the smallest passages through the system....
29th Jul 2016 10:20am |
