Home > Technical (L322) > Radweld?
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Radweld?
Evening all. My FFRR has got a slight weep on the radiator at the moment, it chimes up with Check Coolant every 2-3 weeks and needs a mugful or so when it does. I need to fit a new rad at some point, but due to an ongoing family situation (very sick MiL) and a problem with MrsC's car at the same time, she needs to use mine for a few 160-mile trips.
I fully understand that Radweld isn't an optimum solution from an engineering point of view Razz but just wanted to check, is there any likelihood of fubaring anything else if I whack a bottle in to see us over a month or two blip? I think I'd rather do that than rely on her to monitor the dash and the temp gauge when she's on longish trips on her own!
Thanks chaps.
Post #396514 17th Jul 2016 7:24pm
Jones S13
Don't do it, horrible stuff to clean out. Can cause other issues as well.
Post #396525 17th Jul 2016 8:20pm
Show n shine
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
A big nooooooo
Post #396530 17th Jul 2016 8:30pm
wealy
Nope!
Shocked
Post #396533 17th Jul 2016 8:35pm
It has a very mixed reputation - particularly with modern / complex cooling systems.
My view is that it will get you out of trouble, but cost you more in the long run - because you really need to get the whole system flushed when you do fix the radiator.
Post #396534 17th Jul 2016 8:36pm
Cappo
Thanks all. Alistair's reply above is kinda what I thought and what prompted me to ask rather than JFDI. Probably fine for a 1969 Cortina* but not these days!
*There is nothing wrong with a 1969 Cortina btw!
Post #396536 17th Jul 2016 8:38pm
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
JFDI Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
i like that, that will be copied 2011 Range Rover Vogue SE
Post #398000 28th Jul 2016 8:31am
supershuttle
Mine does the same but I can't actually find the leak. I keep some coolant to the right dilution in a bottle in the boot and top up every now and then. I tend not to wait for "the bong" but just check it cold every so often and add a cupful to bring it up to the mark. Car runs sweet enough, if and when it gets worse I'll get it looked at. Very Happy Geoff
Post #398008 28th Jul 2016 8:57am
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
this may help find your leak then it's a case of fixing it i would use metal putty as a temp solution https://www.amazon.co.uk/Torch-Detection-C...B00TU8VCB4 L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #398014 28th Jul 2016 9:31am
supershuttle
Ivor, when I decide to investigate further that looks like a great way to go - thanks Very Happy Geoff
Post #398019 28th Jul 2016 10:04am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Use K-Seal - doesn't clog up coolant passages etc.
Post #398082 28th Jul 2016 4:08pm
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Just been looking at some of the reviews for k-seal, seems some people did have problems with it clogging up the system... QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #398129 28th Jul 2016 7:33pm
Philip
It's just fine particles in suspension in a solution which becomes some sort of polymer when it comes into contact with oxygen, it can't clog like Radweld-style stuff does.
Post #398142 28th Jul 2016 7:59pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
+1 for this.
I used it on 2 P38's, both of which developed heater "O" ring problems around 70k miles. They both went to over 100k, before I sold them, with no further coolant problems. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #398175 29th Jul 2016 6:42am
Radweld has changed over the years, it's now similar to K-seal, both are fine and designed not to clog the heater matrix, which is usually the smallest passages through the system....
We usually have one old dog in the family fleet and I should get shares in the stuff... always used it, never had problems, mostly people moan it blocked theirs up but it didn't really, they haven't had the coolant changed and over time it sludged up the system, the pressure rose and made a small hole, they put radweld in, it works and seals the hole but the damage was done, it continues to sludge up because of the old coolant and then they blame the last thing that went in there....
Bit like people slagging off power flushes for gearboxes, they have a problem which makes them power flush, the gearbox dies because it was going to anyway and they blame the last thing that was done....
Just my 2p.... Pete
Post #398229 29th Jul 2016 10:20am
