Home > Maintenance & Mods (L322) > Inter cooler bottom hose - certainly not normal
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Morning all!
Well just had a quick once over the car wondering about the smoke on hard acceleration and saw to check the inter cooler hose, which I did and found this (and a whole lot of oil everywhere!)
Any suggestions to whether this has been bodged, or what i would need to do to fix it ?
Cheers,
Steve
Post #396004 14th Jul 2016 9:04am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Looks to be a failed turbo seal/bearings if that oil is coming out from inside the intercooler pipe and not tracking down from outside (unlikely).
You need to check for play in the shaft of the turbo which means removing the air intake pipe (between the turbo and the air cleaner). Once removed check for any free play by wiggling the central shaft side to side, given the amount of oil that's present it should be pretty obvious if it's knackered.
For example this one is totally Censored :
Some play is acceptable as the 'bearings' on the turbo are actually an oil film so there is a clearance to accommodate the oil but excessive play means it's worn, oil will leak out past the seals and you need a new turbo.
Here's an example of acceptable and excessive play:
You will also need the intercooler cleaning out.
Post #396182 15th Jul 2016 9:52am
Stacker
Thanks for your reply will look into this.
Weird thing is my oil level hasn't gone down in 2000 miles. Noticed today the pipe may be slightly dodgy.
Also noticed one of the oil lines connected to the turbo is leaking at the banjo bolt Sad
Post #396443 17th Jul 2016 4:27am
Olly-Ibiza
How many miles has it done, turbos do sweat a bit of oil in the boost pipes, this is the lowest point on the system, if it's been blowing there for a while it will be a bit oily. Maybe take the pipe off and have a look to make sure there's not loads of oil in there, fix the leak take it for a blast see how it is
Post #396451 17th Jul 2016 8:38am
Stacker
It's done 141,000, but this was my thoughts to try the pipe first
Post #396462 17th Jul 2016 10:21am
