![]() | Home > Technical (L322) > TD6 Engine Upgrade to M57 BiTurbo? Has it been done? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
I haven't looked at the Garret turbo, mainly because my unit is still performing fine, at the moment, touch head!
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 ![]() ![]() ![]() |
[quote]It’s always puzzled me that the BMW 730d (E38 shape from 1998 to 2001) used the M57D30 engine (181bhp/410Nm) but with the far superior ZF 5HP24 transmission and not the GM 5L40-E unit used in the X5 and L322 with the same engine.
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
All sounds like good R&D fun but wouldn't you be much better off, financially and in terms of power, by just upgrading to a 5.0SC? |
Not when your covering 30k per year and towing about 50% of the time, if boot space wasn't a requirement, then I suppose that it would be in the running with a stupidly large LPG tank, 200lt's +. But if I had to go that route then a Yank Tank, would probably jump to the top of the list. I will admit that the FFRR is a little bit on the light side for what I'm pulling, but it copes fairly well, and has only forced me to reduce the top speed by 10 mph, but that does add up to rather a lot of time over 15k! |
To be fair there is a decent amount of space under the car to fit some tanks if you really wanted and also chuck the spare wheel as well |
That would be an option, if I could change the rear bumper and not incur the wrath of plod and the insurance companies, because I'd put a swing away wheel on the back. I can't afford to go out with out a spare tyre, getting a puncture is bad enough with out having to pay an extra £160 + vat, to get a new one fitted at the side of the road. I suppose that there is always the expedition route, but the cost of a roof rack is |
Tyre foam and a yellow looking credit car sized object are easier |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
Unfortunately the 5HP30 uses a different casing to the 5HP24 and as the BMW 5, 7 & 8 series, Aston Martin DB7, Bentley Corniche/Arnage and the Rolls Royce Silver Seraph (i.e. all the recipients of the 5HP30) were all rear-wheel drive there isn’t a casing available that will hook up to a transfer box. The F-brake/clutch and sprag assembly is the main common part between the 5HP24 and the 5HP30, though the 5HP24 also borrows a few other bits and pieces from its bigger, older sister e.g. hydraulic spool valves and a few retaining clips.
Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Thanks Phil
chaybra Member Since: 09 Feb 2014 Location: Melbourne Posts: 33 ![]() ![]() ![]() |
Its been a while since discussed....but the 8hp70x as an option?.
Buddy if you can get that to work you'll be a Hero |
