![]() | Home > Technical (L322) > 2nd day of ownership couple of issues |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
when i got mine, i had a bad back sensor. i crawled underneath and recrimped the joins that i found, pushed up near bumper, and it worked.
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
New Harness £40 from main dealers removing the bumper 10minutes
You have to be brave pulling the sides away from below the rear wing. |
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 ![]() ![]() ![]() |
Ordered a new loom, let's hope I'm brave enough get bumper off!
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 ![]() ![]() ![]() |
Don't think that is a light. If you mean the one in middle below windscreen. It is a sensor. But not sure what for. Could be for. Auto headlamps ? 2006 vogue se td6 silver. Bailey unicorn 3 Cadiz . Discovery td5 & many other types before. |
I'm fairly certain it's an alarm indicator and should flash when alarm armed, someone will know if theirs flashes when they lock it ?? |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
As I understand it that 'LED' is actually the solar load sensor for the a/c system so, no, it shouldn't glow at all ... Regards,
Gonna have read the handbook carefully, lets hope your right, in which case I've not got a problem, (was thinking it was like the BMW I've just sold, that did illuminate the LED on dash top when you locked it).
I can confirm the red plastic dome on top of the Dash is a sun light sensor for the HEVAC , it compensates for direct sunlight into the cabin . |
Thanks, looks like I'd invented a problem that didn't exist! Sorted.
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 166 ![]() ![]() ![]() |
Regarding the battery: be very careful to disconnect it the right way. If not, you're going to post a lot more and might end at the dealer's |
Bumper removed, loom swapped, check pdc, nothing!! Swear, put old loom back, nothing! More swearing, put new loom back, works!,, obviously plugged in correctly now. Then one of sensor brackets detaches from bumper, more swearing! Eventually refit it with 3M body moulding tape, bumper back, then spend hour trying re fit rear mud flaps properly. Eventually done and Pdc still working |
The PDC has failed again! This time none of the sensors are ticking, doesn't seem to switch on when select reverse, if switch on it gives a long beep and the indicator on switch flashes but non of the sensors is ticking?..
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Axle and Spooky are correct. The red dome on the dashboard is just a sensor. My car has a flashing red light by the rear view mirror. No longer FF owner but still interested. Present car Jaguar XE
