Home > Technical (L322) > eas again
vmaxer
United Kingdom 2003 Range Rover Autobiography Td6 Cairns Blue
eas again
hi guys really need some help ive had an ongoin issue with my 2003 td6 ,eas inactive to try to get to the bottom of it ive had new battery ,brought snap on ethos diagnostic ,iid tool cleared all faults [abs said air sus can bus ,eas said invalid articulation Shocked drive for around 20 miles then havto start all over again Big Cry my question is how do you no which hight sensor is giving the problem ,it does not come up with left or right hight sensor faulty on diagnostics or am i missing somthing Embarassed Whistle
Post #395612 12th Jul 2016 7:18am
The can bus issue is a generic fault on all of them and you can ignore it, if you have an IID tool you can check the operation of the height sensors (there are four of them) under live values, if they are faulty the IID tool usually has stored codes stating which one... Pete
Post #395655 12th Jul 2016 10:29am
vmaxer
eas again
ok so looked at voltage and its showing LFRONT/RIGHT REAR VOLTS AS 0.05 BUT ON WHAT..... Mad is there a wire that powers some sort of cross link Bow down Bow down Bow down Bow down Bow down :bow:yes i no there,s loads of wires ..
Post #395685 12th Jul 2016 2:14pm
Um.... IID tool doesn't show voltage, it shows a reading from the sensor, how the reading moves when you rock the car gives an indication which one is going bad.... Pete
Post #395693 12th Jul 2016 3:14pm
