Home > Technical (L322) > eas again |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8203 |
The can bus issue is a generic fault on all of them and you can ignore it, if you have an IID tool you can check the operation of the height sensors (there are four of them) under live values, if they are faulty the IID tool usually has stored codes stating which one... Pete
12th Jul 2016 10:29am |
vmaxer Member Since: 22 Jun 2016 Location: staffs Posts: 110 |
ok so looked at voltage and its showing LFRONT/RIGHT REAR VOLTS AS 0.05 BUT ON WHAT..... is there a wire that powers some sort of cross link :bow:yes i no there,s loads of wires .. |
12th Jul 2016 2:14pm |
Um.... IID tool doesn't show voltage, it shows a reading from the sensor, how the reading moves when you rock the car gives an indication which one is going bad.... Pete
12th Jul 2016 3:14pm |
