Home > Maintenance & Mods (L322) > 2 stroke oil in td6
2 stroke oil in td6
i've been reading on the RRS about putting 2 stoke into a tankful of diesel..they claim cleaner and smoother engine running ..anyone tried this? ... - .- -.
Post #39549 26th Nov 2010 3:28pm
Shouldn't need it.
There are loads of debates on the internet as to whether it really works or not
Post #39550 26th Nov 2010 3:32pm
there are positive and neutral reviews , just curious if someone here has done this.. ... - .- -.
Post #39551 26th Nov 2010 3:38pm
I add a bottle of Forte Diesel treatment every now and then just to keep it all clean.
Post #39552 26th Nov 2010 3:46pm
I have heard that using such products can lead to excessive wear of some part or other so be careful....
Post #39556 26th Nov 2010 5:17pm
dan_uk_1984
I cant imagine it's very good for the cats.
Post #39570 26th Nov 2010 6:09pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
I'm pretty sure that modern diesel contains the right amount of cleaning additives etc. Remember that the actual fuel system contains a lot of seals and devices which only expect proper diesel - hence LR even saying that veg oil (SVO which can be used in the old 200/300 Tdi's with no issue) should NOT be used.
Take care when adding foreign substances to your tank, cleaning fuel lines, fuel systems is not a cheap or fun occupation. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #39571 26th Nov 2010 6:15pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
This is the thread that started it all...
http://www.freel2.com/forum/topic878.html
Post #39963 29th Nov 2010 8:13am
