![]() | Home > Maintenance & Mods (L322) > ibus interface possible usefull program |
Isn't it for edditing the computers firmware? Also every time you want to make a change you have to burn a new cd and load a fresh image?
dazdavies Member Since: 26 Oct 2010 Location: st helens Posts: 4 ![]() ![]() ![]() |
i no very little about both tbh i have only seen the display messages been changed
Dan is right - navtweak is for editing the nav's fw. You'll need it if you want to change the splash screen to LR or something RR related rather than BMW when using the latest fw in a MKIII or MKIV nav unit (The MKIII's can only run up to v29 properly, apparently).
Bet Dan get one......... |
noddy5vogue Member Since: 21 Jan 2011 Location: Blackpool Posts: 38 ![]() ![]() ![]() |
Awaiting delivery of my ibus interface just need to trace the correct wire to make ibus connection do you happen to know it ,need it to enable in motion following digital tv upgrade |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
looky here..
