Home > Maintenance & Mods (L322) > ibus interface possible usefull program
dazdavies
United Kingdom 2002 Range Rover Vogue Td6 Buckingham Blue
ive just insalled mine and have been looking around navcoder and after doing a bit of reading have stumbled across navtweek there seams a lot of talk about it on m5 board my question is could this be used on the rangerovers im not a computer genious of any sort but wondered if anyone else has any opinion on this
or am i completely missing something here ?
Post #39535 26th Nov 2010 2:17pm
dan_uk_1984
Isn't it for edditing the computers firmware? Also every time you want to make a change you have to burn a new cd and load a fresh image?
There's not a lot you cant do with NavCoder.
Post #39544 26th Nov 2010 3:13pm
dazdavies
i no very little about both tbh i have only seen the display messages been changed
i have just purchaced the full navcoder and think some of the functions of that are beyond me
Post #39564 26th Nov 2010 5:43pm
SteveMFr
Site Sponsor
Dan is right - navtweak is for editing the nav's fw. You'll need it if you want to change the splash screen to LR or something RR related rather than BMW when using the latest fw in a MKIII or MKIV nav unit (The MKIII's can only run up to v29 properly, apparently).
You can also use it to add detail to the images:
NavCoder is simply for making changes to - or monitoring - the car's settings for many items on the ibus: allowing TV on the move, changing settings on the LCM, etc.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #39628 26th Nov 2010 11:11pm
Bet Dan get one......... Laughing
Post #39663 27th Nov 2010 7:58am
noddy5vogue
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Awaiting delivery of my ibus interface just need to trace the correct wire to make ibus connection do you happen to know it ,need it to enable in motion following digital tv upgrade
Post #47341 24th Jan 2011 8:05pm
looky here..
http://www.fullfatrr.com/forum/topic2862.html?highlight=ibus
btw, found this via the search noddy.. ... - .- -.
Post #47346 24th Jan 2011 8:16pm
