Home > Technical (L322) > What I thought was break screeching in slow moving traffic |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Does it do it if you coast and don't brake? Mine squeal when coasting, then stop when braking. There is nothing that can't be fixed with a hammer😜😜
9th Jul 2016 3:24pm |
nemesisdazza Member Since: 20 May 2015 Location: South East Posts: 76 |
No only when car is in drive and going slow when I press brake? |
9th Jul 2016 3:29pm |
Most likely to be pad squeal if it doesn't do it in drive when you aren't braking then that pretty much rules out everything else.
9th Jul 2016 3:47pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Try 4-5 60 mph to 0 emergency stops.
9th Jul 2016 8:54pm |
Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51 |
40 grit sandpaper on the face of the discs will counteract any "glazing" of the discs and will rough up the pads too.
9th Jul 2016 9:13pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
I've always been told to avoid heavy breaking for a few miles on new discs and pads until they've had a chance to bed in under gentle/normal braking! Apparently doing harsh/emergency braking straight away on new discs risks warping them and seriously reduces the life of the brakes. David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2007 Range Rover Supercharged in Java Black with Ivory Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior |
10th Jul 2016 8:54pm |
