![]() | Home > Technical (L322) > TD6 Gearbox |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Judging by all of the �just out of warranty� (or, in some fortunate cases, still just within warranty) failures reported on the forums for re-manufactured 5L40-E transmissions for TD6 L322s I would say that, as a rule, the source of the original problem (i.e. wear in the valve bodies/pump housing) had not been addressed when the transmission was reconditioned � mainly due to cost. You either need to get specific assurance that the valve body assembly/pump housing has been tested and replaced (or at least fitted with Sonnax valves), or maybe source the valve body assembly yourself.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
Phil, a question. In view of the fact that wear in the valve bodies seems to be one of the primary causes of failure in the GM box, would it be a consideration to change the valve body for a Sonnax one whilst the box is still performing? Provided that there is no apparent "glitter" in the oil. John
Gritstoner Member Since: 15 Apr 2016 Location: Barnoldswick Posts: 10 ![]() ![]() ![]() |
Cheers Phil, I'll give the company on the Wirral a call tomorrow to see if they have an exchange unit. |
Yes, in principle, I think this would be a sensible approach provided the transmission�s clutch packs were still in serviceable condition. Clearly this is hard to judge without stripping the transmission � all we know is once there�s metallic debris in the fluid/sump it�s too late. Sonnax produce kits for no less than ten different valve locations for the 5L40-E Rear valve body : 1. Low pressure control valve 2. Reverse lockout valve 3. 4-5 shift control valve Front valve body : 4. Feed limit valve 5. TCC regulator apply valve 6. 3-4 shift control valve 7. Safety mode valve Pump cover : 8. TCC control & enable valves 9. Line boost valve 10. Pressure regulator valve so I think it would be necessary to test the bodies on a Hydra-Test machine, or similar, to determine exactly which of the valves requires replacement. Each valve kit costs between �50 and �100 so, together with the labour charge for reaming the bores, this would soon prove uneconomic if more valves are replaced than necessary.
It�s also important to remember that several valves are in the pump cover rather than the valve body assembly so this would also have to be tested. Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Great. Please let us know how you get on. Phil |
Thanks for that Phil. Having replaced the filter a couple of times it seemed straightforward to replace the valve block with one already "Sonnaxed". Apparently there is probably more to it than that. |
John,
Phil, I didn't take it as negative at all. Constructive rather than negative. |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
"what is involved with the pump housing?"
Thanks, Steve. I had a look at Rave but wasn't quite sure. |
Yes, the pump housing is bolted to the back of the bellhousing
Regarding testing, the most popular dedicated valve body test machine used in the UK is from Hydra-Test : www.hydratest.co.uk (this is an old video and their data acquisition software has since been updated) An even posher piece of kit is manufactured by Fluidlogic, which is a joint collaboration between John Mackie and BlueReach Automation & Control : Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Thanks, Phil. |
John - no hijack, this is all interesting and useful stuff.
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 ![]() ![]() |
Thanks for this post. I have just purchased and as Swambo says i did my dues diligence and now after a purchase finding out more.
