Home > Maintenance & Mods (L322) > TD6 gearbox oil change question? |
LROMAD Member Since: 10 Oct 2015 Location: Cheshire Posts: 54 |
I have been speaking to my Indy L Rover garage about gearbox oil changes and he said they drop the old and then refill and run it for 20 miles before doing it again . Sounds OK to me . Mines booked in for it next week .. |
7th Jul 2016 2:12pm |
Dr Meat Member Since: 24 Mar 2014 Location: england Posts: 23 |
Thanks, last night I just noticed that the RR is holding back whilst coasting so I tried low range and it had very clunky gear changes. It's a 2005 and done 149,000 I'm hoping a filter & fluid change is in time to save the box |
7th Jul 2016 2:44pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Be aware that you only get just over half the fluid out by just draining the sump. So you need to do several changes in order to get close to 100% clean oil.
7th Jul 2016 3:25pm |
That's why I am thinking I will do an oil change on its own, then after running that for a week I will drain it & then fit the new filter and change the oil again. I've not read of anyone doing this way that's way I thought I would ask the question |
7th Jul 2016 3:38pm |
Sorry Dr Meat I forgot to add that my garage said they would clean out the oil cooler pipes too as part of the gearbox service . Filter change too, of course. Hope all goes well for you. |
7th Jul 2016 9:58pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
Don't think they need cleaning out, if they do then your gearbox is defo toast.... what happens is that they collapse and prevent oil circulating, they can look fine on the outside but the inner layers collapse.... if you have trouble with gearbox overheat then just change them...
7th Jul 2016 10:36pm |
Edd322 Member Since: 27 Jul 2015 Location: Northumberland Posts: 2 |
8th Jul 2016 8:03pm |
You can get close with a power flush but you have to pay someone to do it, buy a 20ltr tub of oil and you get darn close.... and it's cheaper.....
8th Jul 2016 8:19pm |
@ Edd332
8th Jul 2016 9:25pm |
Pete
8th Jul 2016 9:41pm |
Impressive maths calculation Joe! |
9th Jul 2016 4:50am |
Andy K Member Since: 06 Jun 2016 Location: GL Posts: 48 |
All you do is disconnect a cooler pipe at the front.
11th Jul 2016 11:26am |
Sounds good |
11th Jul 2016 11:31am |
[img]
14th Jul 2016 9:12am |
