![]() | Home > In Car Electronics (L322) > Range Rover TDV8 2007 SatNavUnit & Update |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
1..how hot is hot?
vecchifilm Member Since: 08 Jul 2016 Location: Verona Posts: 6 ![]() ![]() ![]() |
very very very hot !!!!
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7975 ![]() ![]() ![]() |
Is it getting hotter - it was only very very hot in the original post |
show me the power connector? I try to disconnect it for a while 'and then hang up.
rear of unit
Is there a separate fuse for it ? |
For fuse i can to see....
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8688 ![]() ![]() ![]() |
It should be possible to disconnect the dvd and then bridge the MOST fibre optic cable using the bic biro method to take it out of the loop. I think. There is nothing that can't be fixed with a hammer😜😜
i would disconnect power first to see if theres a MOST throughput, if not then as above.. ... - .- -.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
Or use a fibre optic loop:
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 ![]() ![]() ![]() |
There is no fibre optic loop on DVD it is just fibre in, not out, it is a spur. 2011 Range Rover Vogue SE |
