Home > Technical (L322) > A few questions about the IIDtool: 02 Readings, Disable EAS |
cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 |
I have an IIDTool BT, and I am running down a lean code with a mechanic, he wanted to see 02 readings and apparently I couldn't find where those readings were.
6th Jul 2016 6:09pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
If you can't find it in the menu then any generic OBD11 reader will show you them, they are there though... mines not BT so can't help...
6th Jul 2016 6:34pm |
I'll look again... I love the EAS but with 108,000 miles on the clock and using the RR for cross country journeys I believe I'll likely switch to springs to save money and eliminate potential failure at the first sign of failure on the EAS. I had a bit of a freightening moment from Los Angeles to Las Vegas in 119 degree heat up hills in traffic, the airsprings started to hiss. I realized later they were over pressure from the heat. OffRoadRover.com An American Western Range Rover Off Road Blog |
6th Jul 2016 7:16pm |
Yeah, true, the heat out there ruins FF's and everything else pretty quick.... Pete
6th Jul 2016 8:26pm |
