Home > Technical (L322) > Suspension fault after map light issue - coincidence?
andygts
While swapping the map lights to LEDs today I managed to grab the old bulb with a pair of long nose pliers and on its way out the wire tail must have bridged the terminals and the switch must have been in the on position (didn't know because the bulb was dead). The interior lights dimmed for a split second and came back. It was the last bulb to change and now I can't get any of the map lights on, the boot light and tiny LED mood light things are also off and the suspension is throwing the code in the screenshot attached, clear it and it comes straight back.
I've checked every fuse behind the glovebox and in the boot, all are fine???
I'm guessing the 2 faults are linked and self inflicted Big Cry but what have I broken?
PS
the suspension seams to work faultlessly it just says it has a fault on the dash. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #394791 6th Jul 2016 5:28pm
andygts
F Censored g things working. Just been out in it and as I turned the key, the offending map light came on and no suspension faults came up. BCM must have had a brain fart and reset itself while it was left. Current
Previous
Post #394802 6th Jul 2016 6:58pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Laughing Laughing Laughing
had this when I did the boot leds, seamed the car didn't want to do anything, I did a battery reset, and hay presto the bloomin thing worked ok.
glad your sorted, the ff is fine sometimes if you just leave it.
Post #394813 6th Jul 2016 7:51pm
