Home > Technical (L322) > 4.4 TDV8 oil filler cap removal!!
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Has anyone ever removed the oil filler cap with the engine running? took mine off tonight and got the shock of my life Shocked . Loud clattering noise, didn't sound at all well but with the cap on all quiet again!!
Has anyone else heard this??
Paul Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #394803 6th Jul 2016 6:00pm
sako243
I wouldn't be surprised since I should be a pretty straight run into the bowels of the engine. Ed
Post #394818 6th Jul 2016 7:25pm
marsie
oh yes, straight onto timing chain. Just a bit alarming to hear it Shocked
Paul Paul
Post #394822 6th Jul 2016 8:15pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Why did you take it off?
(PS a Scimitar GTE is my joint second favorite car of all time - jointly with the GTC) Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #394929 7th Jul 2016 7:32pm
Vogue
What did you think you would find or hear ? Shocked
It's a massive 4.4 V8 diesel engine with 2 Turbo's, timing chain and 16 valves going up and down thousands of times every minute - right inside the valve cover - it's not a euro box with a tiny 1.1 engine Wink You were lucky you didn't get covered in oil. Cool relax the racket is normal - even a small amount of smoke from a tiny bit of blowback coming out of the oil filler is also normal.
You should hear a large tractor or truck engine close up Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #394940 7th Jul 2016 8:19pm
marsie
Need to update my sig line, the GTE went a couple of years ago, to be replaced with a TVR chimaera, then a sierra cosworth, then a porsche 911, then an Audi RS6
Needless to say i get bored quickly Embarassed
Paul
PS Vogue, i worked on trucks for over 15 years but have never heard such a well insulated oil filler cap as on the 4.4 tdv8 Shocked Paul
Post #394943 7th Jul 2016 8:38pm
