Home > Technical (L322) > Steering wheel play? |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Under the air bag - not something you should be playing with if you are not sure.
5th Jul 2016 6:25pm |
Terrier Member Since: 17 Dec 2015 Location: Yorkshire Posts: 51 |
Many thanks mate.
5th Jul 2016 6:32pm |
Those column to rack bolts aren't going to come loose. I know this having tried to replace a similar items on a Disco 3.
5th Jul 2016 6:44pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
The pinch bolt on the lower steering column UJ, which connects the UJ to the steering rack splined shaft, can be found behind the engine tray under the front of the vehicle. You may have to remove the tray to gain access. If this pinch bolt is even slightly slack, it can cause a bit of free play in the steering. It has nothing to do with the nut gehind the airbag on the steering wheel.
5th Jul 2016 7:29pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8626 |
Pinch bolt as said, but check the ball joints on the track rod ends, it's tricky to tell with it on the ground but you can have a look, look under the front of the car by the wheel arches and you will see the steering track rods, if you get someone to wiggle the steering wheel then if there is any play you should be able to see it in the ball joints at the end. There is nothing that can't be fixed with a hammer😜😜
5th Jul 2016 9:06pm |
Get a couple of glossy magazines, one under each front wheel. Get a helper to turn to full lock and then waggle the steering you will see of feel any worn joint, if you don't want to tack it to a garage. |
6th Jul 2016 6:10am |
