Home > Maintenance & Mods (L322) > Front ball joints, what a nightmare that was.
fisha
Spent the day doing 1 side of the front suspension. Took 4 hours getting this bad boy out .....
One of the joints had about 3mm vertical play in it. The knocking had only developed over a few weeks as well. Drives like a dream now. I'll do the other side later this week as my arms need a rest 😀 V8 or else ...
Post #394099 2nd Jul 2016 6:57am
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Your a brave man, hats off to you.
I'd couldnt face a second go at it like you Bow down Bow down THIS WRECKAGE
Post #394111 2nd Jul 2016 7:59am
fisha
The next time round they need done they are generally easier. I tend to hammer the ball joints and they'll likely need done within a few year so won't have seized in place as much as the 8 yrs of the existing ones. That and a liberal amount of copper grease was used. V8 or else ...
Post #394120 2nd Jul 2016 9:06am
Well done that man for persisting and not throwing in the towel and replacing the whole arm....which would have been easier Whistle There is nothing that can't be fixed with a hammer😜😜
Post #394132 2nd Jul 2016 10:11am
fisha
I replaced both the arms too. That ball joint pictured sits pressed into the hub carrier. That would be too much hassle. 😀 V8 or else ...
Post #394138 2nd Jul 2016 11:28am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Next one will be easier, done both mine now, you know where to hit it second time around.
Its a lot easier with the disc removed for anyone who wants to have a go.
Well done. Thumbs Up
Post #394147 2nd Jul 2016 1:36pm
Good point, forgot that it's was on that way round, it's a while since mine were swapped on the old car. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #394177 2nd Jul 2016 7:11pm
