Home > Technical (L322) > Engine check light anomaly
Zain
The amber engine check/management light suddenly came on whilst driving 2 days ago and remained on throughout the numerous starts for the last 2 days.This morning it was still on as i went to work but then the light went out when i started her up to come home.
The car has been running fine both pre and post amber light.
So before i cough up £30 to £50 to get the diagnostic code(s) read would anyone have any idea what it could be that causes the amber check engine light to go out on its own?
Post #393658 29th Jun 2016 4:55pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Poss Lean burn bank one or two or MAF prob (clogged up) but you WILL need to get the codes read to find out exactly what.
Post #393661 29th Jun 2016 4:57pm
Zain
thanks for that ......
......although diagnostics will state the fault code im after a reasoning as to why the amber check engine light would go out on its own without being cleared.
Post #393825 30th Jun 2016 12:08pm
Dolphinboy
If it's the MAF, then the dirt/blockage could have cleared momentarily and the engine runs fine until the MAF malfunctions again?
Are you on LPG? That will have an effect. could need a service or re-set
Post #393872 30th Jun 2016 4:19pm
mr_spock
If you want your codes read, and you don't mind coming to Hertfordshire (J6 of the A1), I'll read them for you. There may be others near you who would do the same.
Post #393881 30th Jun 2016 5:03pm
rangie47
the amber light will extinguish on the 10th (I think) restart .
if the fault has not reoccurred Thumbs Up 2007 tdv8 se ,stornaway grey
Post #393916 30th Jun 2016 7:27pm
Zain
Many thanks for the replies guys.
(Mr Spock - would love to take you up on your kind offer but i just cant get the time out to come up at the moment. Much appreciated).
Post #394351 4th Jul 2016 10:43am
