Home > In Car Electronics (L322) > L322 2002 ibus system
Show n shine
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Is getting a reverse camera installed a straight forward job ? I have a hybrid digital tuner installed oe spec.
Cheers guys
Post #389716 1st Jun 2016 5:52pm
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
Reverse camera for early (BMW) L322
If the car came with the large 7" screen most of the parts are already there.
Extras list -
You need a camera that outputs in American NTSC format.
You need a Video Switching signal circuit
You need a short length of video cable fitted with a female RCA socket on one end (other end bare)
You need a few metres of insulated hookup cable
You need to add 3 recepticals to the plugs on the big silver TV box in the left hand rear side of the vehicle
* The video cable centre goes to White connector pin 13, shield to pin 14
* The Video Switching signal goes to Blue connector pin 17
You need to tap into a (brown) ground wire
You need to tap into the (white) wires going to the reversing lights at the centre rear of the vehicle
* This goes to the camera power AND to the Video Switching signal inverter circuit
Video Switching Signal -
The digital signal inverter circuit consists of a single transistor and 2 low power resistors, total cost around 50 cents. The parts are directly soldered to each other and to 3 wires, then trimmed and then encased in hot melt glue for insulation.
Buy a small signal NPN type transistor, a 10,000 ohm resistor and a 100,000 ohm resistor (One/eight or one/quarter Watt types). Look up the transistor pin out pattern on the internet. Typical part numbers are BC337, BC547/8/9, 2N2222, etc
The 100,000 ohm goes between the transistor Base and Emitter pins, the Emitter then connects to ground.
The 10,000 ohm goes from the reversing light wire to the transistor's Base pin.
The transistor's collector pin goes to the Video Unit's Blue connector pin 17.
Take a look in the Wiki (link at top right of every forum page). The reversing camera install listed uses a much more expensive electro mechanical relay to supply the Video Switching signal, but the pictures are good.
bye.
Post #389945 3rd Jun 2016 2:58am
Show n shine
Cheers. That will be done as soon as possible.
Post #392820 23rd Jun 2016 9:17pm
miggit
Whistle I used a pcb mounting 12v relay which cost less than a quid Wink
If you look in Wiki there is a how to fit a reverse camera section for the 2002-2004 BMW ffrr's, and just a FYI don't bother trying to run the camera video signal in coax in to the plug socket on the TV tuner...... pain in the butt, real easy to brake a wire, just use normal wire for a couple on inches and connect out side the plug Wink I haven't had any interference on my camera Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #393202 26th Jun 2016 10:23pm
