Home > General > First MOT with me
Clivefog
First MOT with me
Passed with advisories corroded brake pipes all four corners, oil leak (don't drip on the drive) and worn edge on tyre - wheels will be refurbed with new rubber soon. I'll have a look at the pipes may just need a clean and paint any thoughts?
What interested me most was the emissions test results, after years of adding veg oil to Diesel to bring the "smoke" test down I now have a CO pass of 0%, HC of 6ppm and a funny squiggle thing of 1.014 at fast idle and CO of 0% at natural idle. Those banks of ECUs are doing their thing. It may gas guzzle but it does it cleanly!
I call him Oliver after Oliver Reed as it drinks like a fish, but it does it in comfort and puts a smile on my face!
Post #392745 23rd Jun 2016 9:02am
For your and other road users safety the brake pipes will require replacement, once they start corroding the rust is rapid and not worth repainting
Post #392748 23rd Jun 2016 9:33am
Clivefog
Not had a look yet, may well strip out and replace. While I'm at it replace the flexi hoses and total fluid flush. Let's hope the summer comes back and I get a chance get under and have a look
Post #392751 23rd Jun 2016 9:50am
johnboyairey
Just to compare, (had my mot this week, passed with advise on brake discs) that's 3 years in a row -of passes..
my figures for the emissions at 165k, are CO, 0.00 (0.01 last year) HC 3ppm (5 ppm last year) and lambda (squiggle) 1.03, (1.03 last year)
Running on LPG
I remember when I had an old jag with carbs. The HC limit was 1500, and I was truggling to twiddle it down to pass.
And the CO was about 6.0 % I think the garage staff were nearly all dead by the time it was passing the test.
I think the bmw engine, is a fantastic design. Even at this mileage, it's well below tolerances. It may have its annoyances, like leaks, and things, but light years away from the old classic generation. Just look inside to compare....no black sludge, no tappets noise, solid idle.
As for brake pipes, read up on the forum. Don't ignore it. Consider some new pipes, via an Indy if you are not confident doing them yourself. Materials are cheap, and with some space, it's not a long job.
I had one fail on my old RR P38. Shocked
Post #392753 23rd Jun 2016 9:56am
Rob99
Don't skimp on anything related to brakes......after all, they're the only things stopping your FF becoming a 3 ton runaway train Shocked Shocked 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #392759 23rd Jun 2016 11:10am
StewD
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Excellent news I bet you were a bit nervous dropping it off... No matter how prepared you think the car is there's always the chance of getting stung...
As above the brake pipes are cheap as chips to sort in the scheme of things. DIY'able with the right tools.
They are the priority now.... Current: Supercharged 06 FFRR in Java Black
Previous: BMW 740D M Sport
Previous Previous: BMW 730D Sport
Post #392850 24th Jun 2016 4:51am
