Home > Maintenance & Mods (L322) > Something fishy with the screenwash |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 |
Phew - what a stink has suddenly started pervading the cab every time I use the screenwash. My daughter says it smells like the dead fish at the bottom of a pond (not too far off) and I have had it previously, but never as bad as this time. I have tried some of that concentrated smelly stuff that you add to the tank, but it just smells like rotting corpses splashed with a bit of the wife's Christmas perfume. I dont know if there are some screenwashes to avoid but I usually just buy the cheapest. I hope I am not about to start a discussion about bacteria etc creating the smell, but does anybody have a suggestion for a screenwash that doesn't smell like an approaching zombie apocalypse? QUID FACIUM TIBI
22nd Jun 2016 8:20pm |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
What about Milton's - that's supposed to be pretty good isn't it. Back in a Defender!! |
22nd Jun 2016 9:25pm |
LROMAD Member Since: 10 Oct 2015 Location: Cheshire Posts: 54 |
I would empty the tank and use Milton (the stuff used to sterilise babies bottles ) .Rinse well and use a good screen wash . |
22nd Jun 2016 9:29pm |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
I've had stinky screenwash when I've pre mixed it & not used it for a while, smells like a rotten pond stirred up.
22nd Jun 2016 9:33pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I would be inclined to empty the screenwash tank and then fill it with a strong solution of water and Domestos and leave it at least overnight before emptying and refilling with new screenwash solution. |
23rd Jun 2016 5:29am |
That's exactly what I had to do. Hot water and strong bleach, give the thing a good shake, leave for an hour, rinse out with a hose. Refill with Halfords purple (Berry smelling) screenwash. Never had an issue since. |
23rd Jun 2016 7:10am |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Screenwash is an alcohol of some kind, (IMS or ethanol) with water, detergent, dye and perfume.
23rd Jun 2016 7:20am |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Just add Miltons or any supermarket brand solution, leave it overnight and expel some through washers to clean the pipes, drain rest from tank and all done. Learnt this from my folding camper after over wintering the water barrel and tap pipes were black with slime. Miltons is non corrosive and mild, household bleach is corrosive. |
23rd Jun 2016 9:24am |
