![]() | Home > Technical (L322) > Brakepad sensor error |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Hi all,
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3258 ![]() ![]() ![]() |
Break in the wiring or insulation inboard of where the sensor connects? John
As far as I can see no... Hope I don't have to disconnect all the wiring to check |
Thanks, tried that as well... Switched key to position 2, (not starting the engine) waited for about 60 seconds... Light doesn't go out... I keep having the red (!) sign and " check brake pads" 2002 L322 V8 |
Bad connection where the sensor cable connects to car harness? |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
From memory, there are only two sensors (one on a front wheel and the other on the opposite side rear wheel) which wear through to ground the connection and this triggers the warning. I would check the other sensor for wear or both sets of cables for a short to ground ... |
Front left, Rear right. |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
There's no short to ground. It's basically a wire 'loop' that wears though, once worn through it's open circuit and 'bong' brake pad wear light comes on. That means any open in the circuit will cause the same error, it makes it a fail safe system. You have an open circuit or high resistance somewhere, usually it's the connector. Paper clip test (if left connected and light remains out for a long time) confirms it's either the connector making a bad contact with the new sensor lead or there's an issue with the new sensor. |
Thanks! Good advice! Will leave the paperclip in for some longer time...
Tried the paperclip... Error came back after a few days (?). Makes me think something is wrong with the connector on the car's end.. But what could be wrong? Looks fine. Wires are connected.. 2002 L322 V8 |
