Home > Maintenance & Mods (L322) > Clunking from standstill
Danwilderspin
Hi guys - when i accelerator from standstill i sometime get a horrible clunk, and sometimes when returning to standstill a weaker clunk.
Was googling and found this - anyone have any further info as to what needs to happen? cheer
4.4 V8 engine: clunking noise
For Land Rover L322 Range Rover models with the 4.4-litre M62 V8 engine, a clunking noise when the throttle is released and applied may be due to a powertrain control module problem which requires the unit to be reflashed.
Post #392429 20th Jun 2016 10:32pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Not heard of this but it could be your loose Brake shields (again)
Post #392503 21st Jun 2016 10:33am
Danwilderspin
Definately not its more of a clonk from under the car either engine or trans you can feel it. It happens sometimes if you accelerate hard from standstill and stop fast from speed...
Post #392509 21st Jun 2016 11:18am
Declan303
Ireland 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Front suspension bushes will definitely give uou a clunk on hard acceleration or breaking, I had it on mine, see here http://www.fullfatrr.com/forum/topic37271-15.html Declan
2003 FFRR Vogue 4.4 V8
97 Defender 90 300 TDi
Post #392512 21st Jun 2016 11:46am
Rob99
On other cars I have had failed engine mounts/dampers clunk when accelerating or braking.
I don't know the FFRR set up (yet) so can't be more specific but might be worth a check 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #392521 21st Jun 2016 12:51pm
