Home > Technical (L322) > Drain hole to engine bay, above battery |
Dave Member Since: 03 May 2016 Location: Norfolk Posts: 187 |
Looking in the battery compartment i noticed the water drain hole thats above the negative battery terminal has no hose, so water would just run onto the terminal, also the large black cable, that has two clips on was just loose, so i pushed it under the bracket and clipped in the holders, i hope it the right way, or should it be on top?
17th Jun 2016 7:07pm |
So should there be a hose under the drain hole ? Dave
18th Jun 2016 6:42pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 |
Yes, a pipe connects to it and then to an exit at the bottom of the wheel arch liner. Look under the battery tray, it's probably slipped off and fallen down. If you can't retrieve it from above then you might have to remove the wheel arch liner from the rear and fish it out that way and re-attach. |
18th Jun 2016 6:56pm |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
No jump lead terminals I'm afraid.
18th Jun 2016 7:15pm |
Cheers gents,
19th Jun 2016 7:16pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Likewise.
20th Jun 2016 1:09pm |
