Home > Technical (L322) > Drain hole to engine bay, above battery
Dave
Looking in the battery compartment i noticed the water drain hole thats above the negative battery terminal has no hose, so water would just run onto the terminal, also the large black cable, that has two clips on was just loose, so i pushed it under the bracket and clipped in the holders, i hope it the right way, or should it be on top?
lastly, where are the jump terminals?
Cheers
Dave
 Dave
2012 Vogue Westminster 4.4
Post #392068 17th Jun 2016 7:07pm
Dave
So should there be a hose under the drain hole ? Dave
Post #392181 18th Jun 2016 6:42pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Yes, a pipe connects to it and then to an exit at the bottom of the wheel arch liner. Look under the battery tray, it's probably slipped off and fallen down. If you can't retrieve it from above then you might have to remove the wheel arch liner from the rear and fish it out that way and re-attach.
Post #392182 18th Jun 2016 6:56pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
No jump lead terminals I'm afraid.
Seems they were done away with after around late 2005. Very handy they were too.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #392184 18th Jun 2016 7:15pm
Dave
Cheers gents,
I looked for the hose but its gone, must be behind the wheel arch liner, i'll take a look for it tomorrow, is it easy to remove the wheel arch liners? Dave
Post #392262 19th Jun 2016 7:16pm
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Steve.
I have the terminals on my 2007, so they were still around for a while, as you say they are very handy.
Cheers, Jerry THIS WRECKAGE
Post #392290 20th Jun 2016 4:58am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Likewise.
I've got them on my 2007
Post #392351 20th Jun 2016 1:09pm
