![]() | Home > General > Hello |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6767 ![]() ![]() ![]() |
Haya Busa, guess you're into bikes then?
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 ![]() ![]() ![]() |
Standard Busa not fast enough for you? |
It was good fun |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Welcome,
Duplicate post Ed |
Olly-Ibiza Member Since: 08 Jun 2016 Location: chester Posts: 49 ![]() ![]() |
The busa was a machine back in the day! |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 ![]() ![]() ![]() |
welcome to the gang Dan
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Welcome |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
My sat nav etc...packed up whilst I was on holiday. I removed the bluetooth unit and found it full of water. Bypassed it and did a temporary repair to get everything else to work and got a new unit from Land Rover with latest software unit for £260. Fitted and all ok, more than likely you will need a new bluetooth unit.
I have emailed Wiggs and he has a newer unit available that will store contacts etc but there are two wires to connect and I have the technical knowledge of a leeming and i am concerned i will blow something up fitting it - I am in West Yorks and I want to get one but concerned about getting it fitted. |
