Home > Maintenance & Mods (L322) > Brake disc anti rust stuff |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
http://en.foerch.com/chemical-products/veh...spray-p321
18th Jun 2016 7:37pm |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
Thank you Weegie. Much appreciated. I'm moving to France permanently in 8 weeks and then off to Italy with my missus for 14 weeks (her job). Both cars are remaining in France for the duration.
18th Jun 2016 8:33pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Good idea but am I missing something, how do you spray the back of the discs to protect them while they are in situ on the car? |
18th Jun 2016 9:02pm |
Same area as before? @ nice day, should think you have to take the discs off. But then if it is for longer than just a week or so then OK. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
18th Jun 2016 9:11pm |
But reading the description of one of the products it suggests it stops the brake pads sticking which implies the discs are left in situ on the car.
18th Jun 2016 9:22pm |
I'm not after a perfect solution, just something to minimize the natural build up of rust that occurs when a vehicle is left stationary for long periods. I expect the pads will still stick to the discs but I also expect the spray will make it easier to free the pads when the time comes to drive the car again. Travelling around in circles again. |
18th Jun 2016 10:55pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
What about a car cover or something to cover the wheels, if water isn't getting on to the disc the rust won't be as extreme |
19th Jun 2016 8:13am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1435 |
Covering the car won't help as the discs will develop surface rust from moisture in the air anyway.
19th Jun 2016 8:18am |
Weegie - Same area, 30 mins S of Bergerac.
19th Jun 2016 2:21pm |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 |
Leave the handbrake off and then as mentioned a quick journey will remove the rust.
20th Jun 2016 7:08am |
