Home > Off Topic - Other Cars > Question about Fuel Guard on Jag XJ
Friggin fuel guard that is on my Jag XJ every time i insert the diesel nozzle it triggers it all the time , i have tried holding the nozzle away slightly even upside down but within seconds it activates the lock .. major PITA ... Can this be removed via a garage ... Always got to get the key out the boot to de activate it ...
TIA if anyone knows 👍
Post #392008 17th Jun 2016 11:24am
ebajema
Sorry, but can't help myself: is that because it is actually a petrol Mick ?????
So got that out of my system.
Sounds like the damn thing is just broken as I don't believe the things have settings options. Probably just needs replacement. MY 2010 5.0 SC Galway green and sand interior!!
Post #392011 17th Jun 2016 11:43am
Wouldnt say its broken Eugene just over sensitive ... Would rather get it taken out than replaced
Post #392013 17th Jun 2016 11:55am
mzplcg
It can be replaced Mick. I had SWMBO's XF done under warranty for the same thing. So, if it can be replaced it must be the case that it can just be removed and not replaced. I'd bet strong money the part is identical too.
As long as only you do the filling up, something I suspect will be the case if your SWMBO is the same as mine, it won't be an issue. Thumbs Up
However, in the event of the second coming of Christ (your Mrs actually fills it up one day) you probably do want to be sure she doesn't fill it with the wrong fuel. Mrs Dom actually asked me one day why petrol pumps had so many nozzles which just goes to show how often she fills up.
Just reminded me, I do recall a bi-fuel Trooper we used to have. She called me from the shoulder of the M6 having run out of both LPG and Petrol. Fuel fairy must have been on strike that week. Banging Head
Post #392018 17th Jun 2016 12:35pm
Cheers Dom , will contact Local Jag dealer 👍 Have to say SWMBO'd doesn't put fuel in mine on the odd times she use's it , but she will fuel fill her own car ... F Censored r ... 👍
Post #392027 17th Jun 2016 2:37pm
