Home > Maintenance & Mods (L322) > 2012 Rear light retrofit |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8328 |
You can't code out the cold or hot monitoring on the side lights or indicators no matter what tool you have... Pete
16th Jun 2016 6:25pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Hi Pete thanks for all the advise so far it's great - I'm definately not saying I disbelieve you but I saw this screen when connected to a rr will this not commit the changes then?
17th Jun 2016 6:33am |
The various computers and software packages allow for changing settings but if the ECU in your particular car does not have the software to use the additional setting it won't work. I don't know what your car is running but I ran into similar issues with my NAS 4.2 where I changed the CCF but no change could be done to either software or wiring issues.
17th Jun 2016 7:36am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Dan, was that computer connected to your car? Or a later RR sir? The LCM on the 02-05 RR will NOT support those changes, however... The LCM on a 05-09 RR will...
17th Jun 2016 9:32am |
That was mine you can see it says module August 2002 I didn't try to write the changes - I may be wrong but I thought the Lcm was based on the e39 module for which I know this works |
17th Jun 2016 10:27pm |
Well give it a try, if it works I'll be round to see you Pete
18th Jun 2016 10:00am |
Jacckk Member Since: 31 Dec 2015 Location: Durham Posts: 18 |
The LCM from the later models works fine in the early cars. I got one for mine and turned off some of the light checking settings which means you don't need resistors or anything else to fit the 2012 lights.
18th Jun 2016 2:50pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
You still need the resisters even with the later LCM ECU, if you don't your rear lights are massively too bright and it looks like your driving round with the rear fog lights all the time
18th Jun 2016 9:17pm |
jam220 Member Since: 08 Jun 2016 Location: Atlanta Posts: 31 |
Hi how are you so Im kinda sort of hijacking the thread and see you are in Durham. Question did you do the facelift on your truck? If so I am in the middle of doing it on a 07 and have a few questions. I have not bought any of the resistors for either front and left but I am talking with Jr eclectic about theirs. What year is your truck and what year did the LCM that you used came from. Thank you |
30th Jun 2016 4:49pm |
