Home > Maintenance & Mods (L322) > Car not being used long term - should I remove battery?
J90
France 2006 Range Rover Vogue Td6 Java Black
Bit of advice required here chaps. I'm going to be working away for 4 months and the car will be left stationary in a safe place. Should I remove the battery or just let it run flat naturally whilst the car is in situ and then charge it up when I return?
I'd rather not leave the keys with someone who may or may not turn the car over regularly.
Ta Travelling around in circles again.
Post #391893 16th Jun 2016 12:49pm
i would disconnect the battery ...dont forget to turn the steering wheel left/right on re-connection.. ... - .- -.
Post #391894 16th Jun 2016 12:52pm
ebajema
I agree with Stan, disconnect and still put a trickle charger, one that keeps the battery in good shape.
Also I would put the car on (wooden) blocks so the pressure if off the tires and a small leak won't end up in crushed sidewalls. May sound a bit over the top but hey, better safe than sorry Wink. I would put the blocks under the suspension arms, not the car by the way, so the car sits at normal height plus clearance (and put it in access height as well). MY 2010 5.0 SC Galway green and sand interior!!
Post #391895 16th Jun 2016 12:57pm
Can you leave it plugged in on a trickle charger ?
Post #391897 16th Jun 2016 1:21pm
Show n shine
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Google ctek chargers.
Post #391902 16th Jun 2016 2:37pm
J90
The car is being left outside but I don't fancy the idea of a long cable across the driveway connected to an electrical point inside the house. I like idea of disconnecting the battery and a couple of wooden blocks under the suspension arms.
I'm just concerned what effect no battery power for 12 to 14 weeks will have on the various electrical systems when I reconnect power. Travelling around in circles again.
Post #391903 16th Jun 2016 2:39pm
J90
I have a ctek charger and the various connections. I shall probably remove the battery completely and connect it to the ctek via a socket in an outbuilding. I'm just not happy having the battery in the car whilst connected to a live socket I have no control over for 12 weeks. Travelling around in circles again.
Post #391904 16th Jun 2016 2:50pm
J90
Show n shine. Are you over on the detailing world forum as well? Travelling around in circles again.
Post #391907 16th Jun 2016 3:13pm
Mr Tee
Disco
Post #391913 16th Jun 2016 4:05pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
If it is left outside, consider a Solar powered trickle charger. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #391914 16th Jun 2016 4:14pm
ebajema
appj 62 has a point, the solar charger has been discussed in plenty posts on here and seem to work well. That way you only have to worry about the blocks Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #391915 16th Jun 2016 4:19pm
take the battery out like you have suggested J90 and its less likely to get stolen... Thumbs Up ... - .- -.
Post #391918 16th Jun 2016 5:26pm
J90
Based upon all of your advice I shall remove the battery completely and connect it up to my ctek. I will also put wooden blocks under the suspension arms.
Thank you all for the advice. Travelling around in circles again.
Post #391921 16th Jun 2016 6:07pm
ebajema
Thumbs Up Thumbs Up Thumbs Up MY 2010 5.0 SC Galway green and sand interior!!
Post #391965 17th Jun 2016 6:08am
