Home > Technical (L322) > Tiny Fan in HEVAC panel ..... Highly likely the culprit! |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 |
15th Jun 2016 9:45am |
calletso Member Since: 27 Jan 2016 Location: North Yorkshire Posts: 12 |
Hi Lamb, a simple trick to test if the fan is still running and for how long, is to put a bit of tissue over the grill on the panel in the dash. The tissue will be sucked to it whilst the fan is running. It will fall off when the fans stops - which you will see through the window of the locked car.
15th Jun 2016 3:19pm |
Would fuse 23 (steering wheel relay) or fuse 29 (steering wheel heater ecu) be ok for a switched feed? Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2 Previous: 2000 P38 DHSE - 1995 P38 DT Man - 1990 3.9 SE Classic, 1980 3.5 Classic 2dr |
16th Jun 2016 1:34pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Try Fuse position 7 which is unused, I have a connector in it and I'm pretty sure it is ignition controlled.
16th Jun 2016 6:09pm |
The L322 2003 Electrical library shows fuse 7 as unused but rated at 5A. Is this still OK to use?. I've bought a 30A fused 4 pin relay (blade fuse) along with an 'add a fuse' connector that allows original fuse back in plus new fuse for extra circuit. With this in mind would I be better using a fuse position that is already rated the same 10A or above?
16th Jun 2016 6:57pm |
Fuse 7 at 5A will be fine to switch the contacts on the relay.
16th Jun 2016 7:13pm |
Ok thanks - a job for tomorrow now if this blooming rain stops!!! Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
16th Jun 2016 7:30pm |
Nicedayforit,
17th Jun 2016 4:49pm |
Good job
17th Jun 2016 5:17pm |
Elduke Member Since: 21 Apr 2013 Location: Glasgow Posts: 148 |
Hi Guys
17th Jun 2016 5:18pm |
Elduke:
17th Jun 2016 5:29pm |
^ That relay will be fine for the job.
17th Jun 2016 5:32pm |
Great stuff guys Ill get that relay and replace the 30 for a 10a
17th Jun 2016 6:39pm |
Elduke
28th Jun 2016 9:47am |
