Home > In Car Electronics (L322) > 2010-2012 ignition feed
i'm going to fit some drls shortly and would like to know if there's an ignition feed and a headlight [dip] feed easily located in the engine bay..
my initial thought was to take the headlight socket off and use a multimeter to find the feeds [as i did on my 2008 SC] but i'm hoping someone will have the info to hand.. ... - .- -.
Post #388345 23rd May 2016 2:50pm
Olly-Ibiza
ignition switched I took from the fag lighter
Post #390738 8th Jun 2016 11:27am
Mcnallykev
Scotland 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
I may be missing something here but if you have a GAP tool why don't you just turn on the DRL's (I'm assuming you have one).
Post #390739 8th Jun 2016 11:29am
@olly, "" in engine bay"
@kev, i have a iidtool and have indeed turned on the drls but they are not very bright hence me wanting to replace the existing fogs with drls.....
i have now found a feed from the fuse box in the engine bay and also a dipped headlight feed and am now waiting for some drl units to arrive.. ... - .- -.
Post #390770 8th Jun 2016 1:50pm
Mcnallykev
Post #390772 8th Jun 2016 2:10pm
i've fitted the drls and have them working ok with a headlight feed switch off function, the only concern is the ignition feed i have from the engine fusebox keeps the drls on for about 15 seconds after i lock the FF, good for 'follow me home' lights but nevertheless a bit disconcerting ...
what i really need is an ignition feed that switch's off when the engine is off....more investigation me thinks.. ... - .- -.
Post #391483 13th Jun 2016 9:23am
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Stan, pics pics! Laughing
Post #391551 13th Jun 2016 9:47pm
Post #391571 14th Jun 2016 6:52am
Whats the issue with the 15 sec overlap Stan? Mine was like that for 2yrs and i quite enjoyed members of the public debating with themselves weather to tell you or not your lights were still on Whistle
As they are LED they don’t take any power anyhow pal Thumbs Up
Post #391583 14th Jun 2016 9:38am
its un-nerving Craig but you're right they are low power leds so no battery drain Thumbs Up ...
its just that until i get used to it, i'm going to have hang around for 15 seconds to make sure they have gone off Laughing ... ... - .- -.
Post #391587 14th Jun 2016 10:10am
ebajema
Rolling with laughter Rolling with laughter Rolling with laughter Stan you have been in FFRRs for too long, always second guessing whether it does what it is supposed to do Rolling with laughter Rolling with laughter Rolling with laughter
The DRLs look very nice by the way !! MY 2010 5.0 SC Galway green and sand interior!!
Post #391611 14th Jun 2016 1:08pm
so true Eugene Laughing
thanks for the compliment.. Thumbs Up ... - .- -.
Post #391612 14th Jun 2016 1:13pm
Lad
I agree, looks good. Nice car too.
Post #391677 14th Jun 2016 10:12pm
Post #391702 15th Jun 2016 7:24am
What kit have you used Stan?
Post #391709 15th Jun 2016 8:22am
