![]() | Home > In Car Electronics (L322) > 2010-2012 ignition feed |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
i'm going to fit some drls shortly and would like to know if there's an ignition feed and a headlight [dip] feed easily located in the engine bay..
Olly-Ibiza Member Since: 08 Jun 2016 Location: chester Posts: 49 ![]() ![]() |
ignition switched I took from the fag lighter |
@olly, "" in engine bay"
Mcnallykev Member Since: 19 Jul 2015 Location: Lanark Posts: 172 ![]() ![]() ![]() |
i've fitted the drls and have them working ok with a headlight feed switch off function, the only concern is the ignition feed i have from the engine fusebox keeps the drls on for about 15 seconds after i lock the FF, good for 'follow me home' lights but nevertheless a bit disconcerting ...
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Stan, pics pics! |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Whats the issue with the 15 sec overlap Stan? Mine was like that for 2yrs and i quite enjoyed members of the public debating with themselves weather to tell you or not your lights were still on |
its un-nerving Craig but you're right they are low power leds so no battery drain |
so true Eugene |
I agree, looks good. Nice car too. |
What kit have you used Stan? |
