Home > Technical (L322) > thermostat removal or not
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
hi anyone removed there thermostat. and will it reduce temp and pressure 4.4 v8 towing large caravan getting slow change up or no change up has anyone cured this yet .had new rad oil flush and change can the ecu be reprogrammed
Post #391437 12th Jun 2016 10:01pm
Personally would not do it. Engine designed to run with a 'stat for a reason. Have you tried / checked your coolant cap?
Transmission flush may not do any good if your oil cooler is all gunged up! Was this checked?
See howto by SaintV8 on removal / replacement, on this forum. .
Post #391444 12th Jun 2016 10:19pm
Clivefog
If coolant is below running (normal) temp the ECU will compensate by increasing fuel thinking it is still in warm up mode. The knock on is high fuel consumption.
Post #391535 13th Jun 2016 9:11pm
rik
hi have changed thermostat for 80 deg no noticeable difference in mpg . lpg changeover time is the same engine def cooler can put hand on top hose now . i have not tried caravan towing yet but will keep posted when i do .engine sounds better and is running great so fingers crossed my mpg is reading 20,4 at the moment and has not changed in 2 weeks give or take .4 mostly urban and a little motorway never above speed limit
Post #403839 7th Sep 2016 11:57am
Dolphinboy
Hasn't this been comprehensively championed by pete/Haylands?
do a search of his posts and you will find all you need. Thumbs Up
Post #403841 7th Sep 2016 12:07pm
