![]() | Home > Technical (L322) > thermostat removal or not |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Personally would not do it. Engine designed to run with a 'stat for a reason. Have you tried / checked your coolant cap?
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
If coolant is below running (normal) temp the ECU will compensate by increasing fuel thinking it is still in warm up mode. The knock on is high fuel consumption. |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
hi have changed thermostat for 80 deg no noticeable difference in mpg . lpg changeover time is the same engine def cooler can put hand on top hose now . i have not tried caravan towing yet but will keep posted when i do .engine sounds better and is running great so fingers crossed my mpg is reading 20,4 at the moment and has not changed in 2 weeks give or take .4 mostly urban and a little motorway never above speed limit |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Hasn't this been comprehensively championed by pete/Haylands?
