Home > Maintenance & Mods (L322) > FBH ??
STU TDV8
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
FBH ??
I removed the fuse on the fuel burner heater (To reset it as i doesn't work) and now it tries to come on when the door's are opened ? , But all i can hear is a fan running but it doesn't run ??..What do i need to do ??.
Post #391421 12th Jun 2016 7:29pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
its probably too warm outside for the fbh to run.
iirc the temperature must be about +8c or below for it to run.
i dont know if you can get it to run any other way.
greg.
Post #391424 12th Jun 2016 7:44pm
