Home > Maintenance & Mods (L322) > steering wheel paddles |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
are these easy to remove? ... - .- -.
10th Jun 2016 8:57pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Why? |
10th Jun 2016 11:06pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3836 |
They're pretty easy to fit so removing them should be easy. I fitted mine so I could more easily engine brake when doing long downhills - yes I know that isn't the modern way but then neither am I. Geoff |
11th Jun 2016 6:27am |
will never use them craig and i dont like them...
11th Jun 2016 6:43am |
sounds risky...i dont want to invalidate the warranty which this procedure might do ..i thought it was just unscrewing them somehow...
11th Jun 2016 8:32am |
Easily removed Stan. And they're only switches for High and Low CAN signals to the box ECU, the ECU doesn't know if they are there or not until you actually use them.. The IID can turn them off as well. I went through this fitting them to my 2010 S/C and the car doesn't complain if they're physically fitted or not. Steering wheel off job and I have the silver backs some place if you want them. |
11th Jun 2016 9:16am |
i was going to use a dremel to cut them off...
11th Jun 2016 9:37am |
Dremel.....you bloody pikey.
11th Jun 2016 9:51am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7829 |
I've never had paddles before, at least not on a car....
11th Jun 2016 9:52am |
^ Yes, and fixed to the column so they don't rotate with the wheel. You always know where they are in one like that. |
11th Jun 2016 9:54am |
@Dom, even taking off the airbag isnt something i want to do at the mo, i'm ocd about making sure things are ok before my road trip ..
11th Jun 2016 9:59am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1445 |
I suspect they are designed like that so that you dont have to move your hands around the steering wheel......think F1 steering wheels 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
11th Jun 2016 10:02am |
Well the ones in the Wife's Aston are fixed and they are much easier to use. F1 wheels don't turn more than 180 degrees so there's no arm twirling going on so it makes sense there. Less so in a car with 2 or 3 turns from lock to lock. |
11th Jun 2016 10:21am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3778 |
For what it is worth Stan, I didn't use my paddles in the first 6 months of ownership.
11th Jun 2016 11:27am |
