Home > Maintenance & Mods (L322) > steering wheel paddles
are these easy to remove? ... - .- -.
Post #391139 10th Jun 2016 8:57pm
Why?
Post #391160 10th Jun 2016 11:06pm
supershuttle
They're pretty easy to fit so removing them should be easy. I fitted mine so I could more easily engine brake when doing long downhills - yes I know that isn't the modern way but then neither am I. Very Happy Geoff
Post #391167 11th Jun 2016 6:27am
will never use them craig and i dont like them...
i suppose its a steering wheel off jobby geoff? ... - .- -.
Post #391168 11th Jun 2016 6:43am
Oh ok... Im guessing you will throw up a gearbox error though Stan... Thats why i asked...
You can simply remove them (unplug the elec supply) and fit the lower silver covers (you usually remove them to fit paddles...) BUT, as i said above... Im sure you will cause issues with the trans ECU...
Maybe drop Christian from GAP an email?
Post #391177 11th Jun 2016 8:08am
sounds risky...i dont want to invalidate the warranty which this procedure might do ..i thought it was just unscrewing them somehow...
many thanks for your expert input craig [as always] Thumbs Up ... - .- -.
Post #391185 11th Jun 2016 8:32am
mzplcg
Easily removed Stan. And they're only switches for High and Low CAN signals to the box ECU, the ECU doesn't know if they are there or not until you actually use them.. The IID can turn them off as well. I went through this fitting them to my 2010 S/C and the car doesn't complain if they're physically fitted or not. Steering wheel off job and I have the silver backs some place if you want them.
Post #391196 11th Jun 2016 9:16am
i was going to use a dremel to cut them off... Laughing
cheers for the info [and offer] Dom, after thinking about this ,i'm going to put this idea on the back burner for the moment as i'm off to the french alps next week and i dont wont to risk any problems occurring.. ... - .- -.
Post #391199 11th Jun 2016 9:37am
mzplcg
Dremel.....you bloody pikey. Rolling with laughter
Whip the airbag off and you can disconnect them without physically removing them. That should set your mind at rest about errors if you use it like that for a few days. Then go the whole hog once you're happy.
Post #391202 11th Jun 2016 9:51am
mjdronfield
I've never had paddles before, at least not on a car....
I don't really use them but I have found them good for dropping a couple of gears for a swift overtake. It's probably me, but it seems a bit hit and miss getting a quick down change using the accelerator....... Perhaps I need to learn how to drive again!
I don't like the plastic though, should have been aluminium for the feel of quality..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #391203 11th Jun 2016 9:52am
mzplcg
^ Yes, and fixed to the column so they don't rotate with the wheel. You always know where they are in one like that.
Post #391204 11th Jun 2016 9:54am
@Dom, even taking off the airbag isnt something i want to do at the mo, i'm ocd about making sure things are ok before my road trip ..
i'll play with it when i'm back Wink .......and stop sending me dirty text messages Laughing ... - .- -.
Post #391207 11th Jun 2016 9:59am
Rob99
I suspect they are designed like that so that you dont have to move your hands around the steering wheel......think F1 steering wheels Very Happy 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #391208 11th Jun 2016 10:02am
mzplcg
Well the ones in the Wife's Aston are fixed and they are much easier to use. F1 wheels don't turn more than 180 degrees so there's no arm twirling going on so it makes sense there. Less so in a car with 2 or 3 turns from lock to lock. Thumbs Up
Post #391210 11th Jun 2016 10:21am
Baltic Blue
For what it is worth Stan, I didn't use my paddles in the first 6 months of ownership.
Then I found out oil was building up because the revs never got high enough to run the second turbo.
I regularly drop down a couple of gears when I am on a clear bit of motorway now just to burn it off.
Yours may have the oil pipe mod done being 2012 ?
Post #391216 11th Jun 2016 11:27am
