![]() | Home > Technical (L322) > Wanted- better V8 M62 radiator |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 ![]() ![]() |
Does anyone make a better radiator for the M62 V8 RR than the OEM unit? Mine has started to leak again. It was last replaced in mid-2014.
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3194 ![]() ![]() |
I replaced mine with a Hella one. I think that is the OEm one? no probs so far. |
Yes, I've seen mention of the Hella unit. I checked with my supplier today and they can get the Hella. Is it the same Hella as in lighting?
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
I put a Hella one on mine as well, nearly 5 years later and it's still fine. I thought Hella was OEM too. |
What pressure coolant reservoir caps are you using? Mine had a 200kPa cap but now runs a 140. Ron B. VK2OTC
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8353 ![]() ![]() ![]() |
The very first cars ran a 140 cap, they then went to a 200....
I fitted one of those a few weeks back, Pete.
Re the above, what I don't understand is the VIN. The 1A indicates a 2001 build/model but the L322 didn't start until 2002.
Mine was Sept 2002 and it's number is 3A******
Yep, Sept 2002 is a 2003 MY. Ron B. VK2OTC
