Home > Maintenance & Mods (L322) > Rear window relay |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
I take it these are other faults you have... pretty sure they are on the BECM so maybe yours is toast...
5th Jun 2016 5:54pm |
STU TDV8 Member Since: 03 Apr 2016 Location: norfolk Posts: 65 |
Im not sure what's wrong , I had an issue with my air suspension which ended up to be a high resistance joint in the boot where the 3 earth's are behind the spare wheel . So fixed that then when to test drive it up the road and the steering was heavy and the rear two door's both had electric window issue's ? . Also the top tailgate doesn't open on the key or dash control etc ??.... |
5th Jun 2016 6:36pm |
In that case I'd check the earth under the carpet at the front, it will mean taking the passenger seat out and side trim and carpet...
5th Jun 2016 7:03pm |
This is the earth point, all the brown wires...
5th Jun 2016 7:07pm |
Thank's haylands you have been a great help ill do it in the next couple of day's !... |
5th Jun 2016 7:17pm |
If you want to test it before it goes back together, just lay the seat in place and plug it in, wouldn't drive far though...!!!
5th Jun 2016 7:24pm |
Tested the earth's tonight and there all good so guess it's the BECM ? .. |
7th Jun 2016 9:36pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
There has been a spate of Body Processor Modules failing recently mine included , all around the same age as well . 2008 MY Supercharged
8th Jun 2016 1:01am |
Anybody know if the TD6 BECM unit will work on the TDV8 2007 ?.. |
9th Jun 2016 8:42pm |
Give Dan a ring, or send him a message he'll be able to tell... Pete
9th Jun 2016 9:37pm |
