Home > Maintenance & Mods (L322) > fuel additives |
Carries more weight (for me) than a bunch of personal opinions based on nothing more than a gut feeling. Remind me, who makes 2SO? Oh yes, an O+G company. They have no axe to grind either way. |
5th Jun 2016 7:51am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
My twopenneth worth. I have a kangoo van that I have had from new and it's now done over 200 k
5th Jun 2016 8:02am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I would be very careful about calling out the validity of this study ,the methodology is well laid out for anyone wishing to repeat it and it is cited correctly for all references . yes he works in the O+G industry but as an expert where else would he work other than academic research and as I have said his methodology seams sound . Anecdotal evidence as we have heard from many sources on this and many other matters are not evidence of anything just someone who can tell a story . 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
5th Jun 2016 8:36am |
Oh, so it's a passion wagon then Clutches I guess, hell I could live with that.
Oh I would. I'd add some spark plugs and a supercharger. Joking aside though, I think you're on the money there. I don't put anything except diesel in my Skoda (work hack) and it's turned 200k without anything beyond routine maintenance. To be honest it still feels as it if would do it all again. No black smoke, no oil consumption, just a sweet drive which still gives over 50mpg average. Does need a clutch though, well actually it needs an autobox but there we go. |
5th Jun 2016 8:53am |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
I disagree. While the methodolody may be perfectly clear and correct, it is only a single study, on a single type of engine. Anecdotal evidence may be just that, but it is also from hundreds of people over hundreds of miles and in many different engines, so it is every bit as valid as evidence. Clear reductions in fuel consumption and lack of any issues are pretty clear cut matters not just an opinionated story, and most people are sceptics when they first try it. I don't see people falling over themselves to state that 2SO has wrecked their engine either - only people that think it will and so don't use it. From a purely logical perspective, I believe that, rightly or wrongly, the anecdotal evidence carries much more weight. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
5th Jun 2016 10:13am |
Whilst everyone is entitled to there opinions if something can be asserted without evidence then there is no evidence at all .The reason so many pseudo science whack jobs like the anti-vaccine or anti GMO activists get momentum is by people asserting their opinions as fact , I'm not saying that report is right or wrong I'm saying it is the only evidence presented and its source is immaterial to its validity, that is all . 2008 MY Supercharged
6th Jun 2016 4:54am |
Yes, but where do you get the opinion from? There are enough people, myself included, that have seen clear improvements in fuel economy over many miles. Just because it isn't in a controlled environment and tested scientifically doesn't mean that it's not evidence when observed on such a scale. It should not be considered conclusive, but it is still evidence to be weighed up. Visiting from DISCO3.CO.UK
6th Jun 2016 7:50am |
SNR Member Since: 16 Mar 2016 Location: Northen Michigan Posts: 15 |
My other vehicle is a 1995 F350 Powerstroke diesel on 35 inch tires, I add one quart of two stroke oil to both tanks every time I fuel up and have for the last 6 years. My truck runs much smoother, starts faster, doesn't smoke and my exhaust gas temps stay lower. I'm not trying to join a debate, just give my results and state that it does work. 20 mpg in a truck that weighs almost 8000lbs is all the proof I need. |
7th Jun 2016 1:21am |
I guess they hadn't invented DPF in 1995 so that would be OK. |
7th Jun 2016 8:33am |
DPF vehicles need JASO FC spec or better. Visiting from DISCO3.CO.UK
7th Jun 2016 8:49am |
Wealy, right you are. That is most of the reason for the two stroke oil in the fuel. When they "cleaned up" the diesel fuel they stripped out most of the lubricants. Again, not trying to get into a debate. But, by adding the oil you replace some of those lubricants and because two stroke oil is ashless, it burns very well and does not create residual problems like gumming up the turbo or increase coking. Newer diesels(2007+ in the US) do not have any of these problems and yes they must use a DPF. |
7th Jun 2016 5:41pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
I have used it on my Td6. After becoming very unsure where to connect the hoses I just got a new fuel filter, filled it up with the product and the run the engine on tick-over as required. I am sure you could do the same with the TDV8 2007 TDV8 VSE
1st Apr 2019 2:32am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Hi everyone, sorry to resurrect an old thread, not sure if it's verboten to start a new thread on here for an old topic - or not...
16th May 2022 6:06pm |
In the absence of any better ideas, I put 1 litre of Kero into the tank which had ~10 litres in it, added 200ml of Cetane booster and went for a steady 40 mile drive (10 mile loops on a dual carriageway), brimmed the tank, another 20 miles at a steady 60mph but in one gear lower than 'D', as before. Result was no eye-watering stink, no black smoke on acceleration and better throttle response. Emissions check was well below the threshold for the MY. |
3rd Jun 2022 9:27pm |
