Home > LPG > Low Lpg range |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Gosh that's not good.. Simple maths - 93 ltrs = 20 gallons , 115 miles / 20 = 6 mpg.
27th Apr 2016 2:19pm |
blackstoun Member Since: 22 May 2015 Location: Scotland Posts: 116 |
Its worth noting that 20% of your LPG tank capacity is not usable . e.g. a 100L tanks has only 80l usable
27th Apr 2016 2:42pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 337 |
As per what Blackstoun, above, says, there should be approximately 68 - 71 litres of LPG in the tank but 115 miles from a tank is not good. I've been running LPG for over a decade on my cars and I run a 4.4 at the moment and also a 1.4 Astra on LPG. Whilst it's fair to say I'm slightly disappointed with the MPG I've got generally from the FFRR, I've had extremes of 135 miles to 280 miles from my tank (compared to 500+ miles from 68 litres in the Astra). On average its giving about 200 miles but I have recently changed all 8 injectors for smaller flow units to test them but have retuned the system as well. I am working with an LPG installer in Solihull (Solihull Autogas) to see what the best setup is. He has an M62 powered 5 Series which gets 300 miles from 60 lites so the shape and the weight of the FFRR must be a serious factor. I am also in the process of changing all four lambda sensors for brand new bosch units to see if they are a cause of poor economy as the sensors are a replacement / service item. All of the spark plugs are also LPG plugs sourced from Oilman on this forum.
27th Apr 2016 4:04pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 456 |
I have a 100ltr tank of which 80ltr is available and I get around 215 miles per 80ltr |
27th Apr 2016 4:05pm |
Angus.myers Member Since: 27 Apr 2016 Location: Manchester Posts: 6 |
Hey thanks for all the replies so far, I've just realised that it flashing isn't empty its reserve (sorry i'm new to this whole LPG business) its still flashing and I'm closer to 150miles now, is that any better. Its the BMW 4.4 and seems to have been well looked after in the past (bought from sir alan sugar so I'm hoping it was maintained well, it only has 70,000 on the clock). The check coolant message came up yesterday and i checked and it was empty in the tank could that have anything to do with it? I've topped it up and praying there isn't a serious leak somewhere...but thats an issue for another area of the forum :O
27th Apr 2016 11:50pm |
Yes, that's much better mileage.
28th Apr 2016 7:13am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Same sized tank as my car - i get from 150 miles up to 270 on a long run, it really depends on the type of driving i'm doing. I'm a fairly gentle driver but driving in london ruins the consumption. |
28th Apr 2016 10:11am |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 |
It the three tanks we've done in our new one we're getting 220-230miles per tank. Thats a 68/69l fill on an 85l tank.
28th Apr 2016 2:02pm |
I don't measure by the fuel light. I measure mileage from full to empty |
28th Apr 2016 3:48pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
@Angus
28th Apr 2016 6:11pm |
had to fill up yesterday as i'd run out of LPG.
1st May 2016 9:49am |
Sleeper Member Since: 01 Jun 2016 Location: Birmingham Posts: 55 |
Just got back from filling up 40p per litre at the moment.
4th Jun 2016 2:41pm |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2288 |
Normally I get around 250 mls on 70 ltr highway and 220 in town. AjV8 |
4th Jun 2016 7:29pm |
Frank Elson Member Since: 20 Feb 2016 Location: Blackburn, Lancashire Posts: 34 |
As others have said, the led lights are inaccurate. The only accurate method is to fill the tank. zero your tripmeter, then run it until it changes over to petrol - forget the "low" indicator, let it actually change over.
11th Jun 2016 9:05am |
