![]() | Home > My Range Rover > Project Fatty off roader....PICTURES NOW BACK |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 612 ![]() ![]() ![]() |
Simples |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8394 ![]() ![]() ![]() |
A long while ago a very nice person off this forum sent me the front pulley and bearing from the Air conditioning pump, I was a bit of a |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Hi pete, glad it was of use. Still got mine to do.
It was of massive use, thanks mate, nice to be able to see what your trying to remove, did it all with a mirror propped against the radiator... I would have had to remove the pump and empty the system otherwise, and that looks like a real fun job, you can't see the pipes or mounting bolts and there is little room to play with... And the new ones bearing is spot on... |
That's good to know, hope there is more access on the TD6 than the V8 though... |
Update time... but on me, not the FF
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
All the best Pete, good as new soon |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
Good luck with the op and a speedy recovery. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
good luck Pete, hope it all goes well... |
Cheers chaps, just means I'll be on here more.... |
I set them off already, no chance after a knee as well....... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Good luck pete, hope your up and about soon.
i'm due for 'spinal cord stimulation' operation soon and that has some weird stuff that will interfere with it.....we would make a right pair at an airport Pete.. ![]() Y. O. L. O. . |
One of those will probably upset your FF Stan... too much static.... |
