Home > Maintenance & Mods (L322) > HID Headlamps
PerplexedLR
2005 Range Rover Vogue Td6 Bonatti Grey
HID Headlamps
Hi
Has anyone fitted aftermarket HID's to replace the OE units that are currently driving me crazy with flickering and failure unless switched off and on again.
If so make, source and aggro factor whilst fitting info would be most gratefully recieved.
Thank
Post #390006 3rd Jun 2016 10:11am
do you mean replace the xenon bulbs or the whole xenon light unit...if the latter then it cant be done.. ... - .- -.
Post #390008 3rd Jun 2016 10:14am
PerplexedLR
Bulbs and ballast resistors/igniters I guess?
Post #390009 3rd Jun 2016 10:15am
is it just one side or both...if one side you could change over bulbs first then the ballasts, its a process of elimination.. ... - .- -.
Post #390010 3rd Jun 2016 10:17am
PerplexedLR
Annoyingly, both sides intermittently...
I've cleaned up connections etc but no improvement.
Seen a replacement kit at 'My HID.co.uk' but unsure if I would be wasting the £200 required...
Actually, its not the money, I'd be happy to spend that and more for a proper solution as it is becoming a lost cause and I find myself using another car at the slightest prospect of running into darkness!
Post #390011 3rd Jun 2016 10:24am
PerplexedLR
This is the kit I've seen on the web
http://www.hids4u.co.uk/D2R-D2S-HIDS4U-Ste...n-Kit.html
Regards
Post #390018 3rd Jun 2016 10:40am
how about one or two complete headlight units ..bound to be some on ebay or try our site sponsor Craig @ Cam-tec, he's got loads of bits in his cave....
.....and as far as i know , no one here has done that kind of conversion.. ... - .- -.
Post #390022 3rd Jun 2016 10:44am
PerplexedLR
Thanks for the info
I'll speak to CAM TEC
Regards
Post #390026 3rd Jun 2016 10:48am
