Home > Technical (L322) > Leaky gearbox |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
I’ve never done it from underneath a vehicle, only on a bench, but it certainly looks straightforward enough.
2nd Jun 2016 10:36am |
craig nicholas Member Since: 08 May 2016 Location: Lancashire Posts: 32 |
Phil, Thanks for the info, I appreciate that. I have found a kit that I intend on ordering .
2nd Jun 2016 10:43am |
The filter is an integral part of the plastic sump pan. I’d encourage you to use a genuine IBS Filtran filter/sump pan and ZF LifeguardFluid 6 fluid, rather than cheap pattern parts, if your budget can stretch to it.
2nd Jun 2016 11:22am |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
Changed our connector sleeve whilst changing the filter and oil.
2nd Jun 2016 11:13pm |
Thanks Steve and Phil. I ordered O.E.M parts and ZF fluid cost slightly more . We're having a new driveway done starting Monday and the gearbox kit is only due Tuesday! The wife ain't going to be impressed if it spills everywhere. |
2nd Jun 2016 11:39pm |
For info. here’s the fluid level setting procedure :
3rd Jun 2016 8:34am |
Thanks Phil.
3rd Jun 2016 8:52am |
Andy K Member Since: 06 Jun 2016 Location: GL Posts: 48 |
Just make sure you apply WD40 into the thread top and be careful not to snap any of the bolts off.
6th Jun 2016 11:43am |
Thanks Andy. I've had a look under mine (ffrr) and access looks fine. The parts I ordered arrived this morning . I will update in due course. |
6th Jun 2016 1:50pm |
If you have complete clearance at the front of the gearbox you should be ok. |
6th Jun 2016 5:36pm |
Ok. Ive drained the oil and just sat waiting for the drips to finish. Whilst im sat with time on my hands I'm working out my next move.
7th Jun 2016 3:05pm |
Also on this subject ... I have a kit that includes 7 ltrs of gearbox oil but only actually took out approximately 3 Ltrs ???
7th Jun 2016 3:09pm |
The filler plug is also the level plug so make sure that you follow the refill procedure that I posted above.
7th Jun 2016 3:25pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
I think this is based on the 'double flush' method.
7th Jun 2016 3:26pm |
