Home > Maintenance & Mods (L322) > L322 td6 radiator removal help please.
Show n shine
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Good evening guys, I'm in need of assistance on the removal of my radiator as there is a pin hole leak. There is vast amounts of information on the the v8 model's but nothing on the td6. Which I found strange.
Changing a radiator has never bothered me in any other cars. But the m57 has the viscous fan in the way. I've never messed about with a viscous fan before. I've also read the nuts are opposite threads ??
I just need direction's on how to remove the fan nut and what 2 tools are required. Big Cry
Help please.
Post #389700 1st Jun 2016 3:34pm
mr_spock
From RAVE it looks like it's the same as the V8. Since you're in Hertfordshire, don't waste your money buying a fan tool. PM me, come over at the weekend with your new coolant and we can get it changed.
Otherwise, get the fan removal tool from Halfords for about £13, put it on the nut, get a big hammer and give it good hard smack to the right as you look from the front of the car. Don't just tap it, CLACK IT ONE and it will come loose. [/code]
Post #389705 1st Jun 2016 4:05pm
this is from our wiki and although its for the v8 it should give you an idea,
http://www.fullfatrr.com/forum/topic16155.html ... - .- -.
Post #389709 1st Jun 2016 4:23pm
I found it easier with two spanners, one to hold the pulley the other to undo the fan nut. The Halfords ones are "not quite" long enough either. (the good whack method does also work, though)
Yes, remember the nut on the vicious fan is left hand thread, so undo clockwise.
In terms of removal, iirc:
0. remove undertray
1. Drain radiator
2. Remove hoses & other connectors
3. Undo fan shroud (gives better access)
4. Remove fan (the fun bit)
5. Remove shroud
6. remove radiator
Consider not putting the fan back, just not needed on TD6 (as long as your air con fans are working OK) .
Post #389719 1st Jun 2016 5:11pm
Show n shine
So the aircon fan also works as rad fan ? Is this correct ?
Post #389721 1st Jun 2016 5:24pm
mr_spock
Just to add - I found it necessary to remove the undertray to disconnect the gearbox rad. I guess the TDs don't have one?
Post #389722 1st Jun 2016 5:37pm
Show n shine
I have the under tray off as I steam cleaned all the underside. I will be underbody sealing and waxoyling. Just because I love to tart her up. Laughing
Post #389726 1st Jun 2016 5:51pm
Sorry forgot to remove undertray (have added now)
The air con rad will contribute to main rad cooling. On a really hot day in traffic I hear it kick in, but then I have the air con running so you might expect it.
Never seen the needle waiver from 12 o'clock whilst running without the vicious fan (but have changed main and egr thermostats too!) .
Post #389761 1st Jun 2016 8:41pm
Show n shine
Right. Productive day guys. Changed the rad without taking out the fan and cowling. Replaced with with an oe part behr. Done a flush with water a few times to totally get rid of old coolant. Tomorrow I will add need coolant with the correct mix. I also got to work with the rust on chassis with krust and will be underbody sealing and waxoyling.
Post #389875 2nd Jun 2016 5:15pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Can you give a step by step guide how to remove the rad with the cowl and fan in situe 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #389967 3rd Jun 2016 8:09am
Show n shine
I made sure to that the coolant clips undone before I emptied the coolant.
Drop the coolant
Coolant pipes off
Undone the electric plugs just incase I shafed it on anything.
Undo the plastic nuts that keep the rad sterdy
Once that is done you need to remove it he red bleed valve on bottom of rad as you know space is tight as a n... Censored
With that done.
Now move the rad towards the cowling and is ready to be pulled out. Now at this stage you will need 2 pair of hands as I did.
1 to keep the cowling pushed towards the engine and other to pull rad up. As you pull up the you need to bend the plastic side bracket of cowling to get the rad bleeder out.
I was not bothered about further damage to old rad as I pulled out. But to instal it's reverse principal.
It can be done, as I had done it.
I did not put coolant I n but just added water with a few flushes.
Topped up with water n bled the system just to make sure there were no more leaks.
Finally done a correct antifreeze mix.
Post #390076 3rd Jun 2016 1:30pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
S n s . Well done. Thumbs Up
Post #390120 3rd Jun 2016 6:37pm
wayneg
Thanks for the how to. Thumbs Up 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #390147 4th Jun 2016 12:04am
